Looking on how to setup virtual dj to send/receive NDI video to a 2nd computer(resolume). I installed the plugin in virtual DJ and installed NDI tools on 2nd computer. Hooked up ethernet cable to both computers. In virtual DJ selected SEND-NDI in video fx box...I am lost after that. I am not familiar with network settings or addresses. Is there a video or how to somewhere? Thanks for any help!
geposted Thu 16 May 24 @ 4:24 pm
As long as the two computers are on the same network you should not have to mess with IP addresses etc.
VirtualDJ should appear as a source in the "Sources" tab on Resolume.
PS: An ethernet cable between two computers directly won't cut it (because of how computer networking works these days)
So, make sure that you use proper network infrastructure (a network switch and/or a network router with a DHCP server running on it)
geposted Fri 17 May 24 @ 12:55 am
Thanks for the reply !
Ok, I disconnected the ethernet cable... Re-booted both computers...Selected "send -NDI" On deck #1 Vdj computer. Now on the Resolume computer (under sources) I have a link to VDJ deck #1. I added link to Layer ... but only have a black screen? So close! Any ideas? Also If I select "Receive NDI" on deck #2 Where would source show up in virtual DJ ?....
geposted Fri 17 May 24 @ 1:57 pm
So by Selecting "Send-NDI" (on BOTH decks in Virtual DJ) I am able to see video on Resolume computer. But when playing video back on the resolume computer there is a very bad lag and not synced to the audio? I am home working on this .... could it be that the computers are connected thru WiFi ? Is there a different way to do this? (video or walk-thru somewhere? I can't take a chance at a venue ! Also how does "receive-NDI" work or so up on Virtual DJ computer?
geposted Fri 17 May 24 @ 2:59 pm
What exactly are you trying to do?
I can understand sending stuff from Resolume into VDJ (which is what I do when streaming) but you're going the other way.......and then trying to send it back again?
geposted Fri 17 May 24 @ 3:13 pm
How is this done (sending from resolume to VDJ )???? Where does it show up in VDJ????
geposted Fri 17 May 24 @ 3:59 pm
Just want the dancing super heros video.... Unable to play in resolume (different file format).
I have a job coming up and they would be great!
geposted Fri 17 May 24 @ 4:02 pm
You can play those in the VDJ sampler. If you want to extract the loops of each character, they're just MP4 files.
geposted Fri 17 May 24 @ 4:11 pm
I do not know file type??? Unless I am in wrong folder???
https://www.virtualdj.com/img/406047/47801/20240517_125702.jpg
geposted Fri 17 May 24 @ 5:01 pm
What is VJ sampler???
geposted Fri 17 May 24 @ 5:02 pm
geposted Fri 17 May 24 @ 5:55 pm
The best way is like you said ... just grab the files. Can you provide location in VDJ folder for Animation? I do NOT think I am in the correct folder????
Thanks
Thanks
geposted Fri 17 May 24 @ 10:40 pm
Maybe I missed it ... could not find anything about loop files? Or anything about NDI usage...
Sorry for all the questions ... I am new to this video stuff. I have a large rig and do lighting shows and trying out some video.
geposted Fri 17 May 24 @ 10:50 pm
The zip files that you downloaded (Let's Dance - Superheroes) are for use with the VDJ sampler. Just load that bank to the sampler and press the pad(s). They'll play on the video output.
geposted Sat 18 May 24 @ 8:39 am
The problem is I want them on the resolume computer to use them as effects.....Thanks anyway
geposted Sat 18 May 24 @ 11:44 am
Use them as effects? They're not effects, they're video loops.
geposted Sat 18 May 24 @ 3:56 pm
