Topic: Questions about using older version
Hi folks,
I'm afraid the update to MyLists and .vdjfolder instead of .m3u has interrupted a valuable function of mine.
I use VDJ as a music video playout tool (I know, but it's the best option for my implementation), I wrote a program that would rotate all the .m3u's every 24 hours so that every playlist always played in a different order, really useful and a strong feature.
What are the realities of staying with 2023 and never upgrading? Or are there workarounds to continue using .m3u's with 2024?
Thanks,
Mike
geposted Fri 17 May 24 @ 10:15 am
m3u is still supported, so you don't have to change anything.
If you used the VirtualDJ\Playlists folder, that is not visible by default anymore, but you could create a shortcut to it, or save the playlists in a different location.
geposted Fri 17 May 24 @ 10:31 am
Thank you , I did suss that *.m3u still worked but not from the /playlists folder, so are you saying that any other folder will perform the same function?
Thanks
M
geposted Sat 18 May 24 @ 2:00 pm
It does! Phew!
Thanks Adion.
geposted Tue 21 May 24 @ 10:24 am
