I would like to request that you add the ability to choose BPM Range like you can in Serato, Rekordbox and Djay Pro.
Thanks
Thanks
geposted Mon 20 May 24 @ 9:56 pm
There are a few ways to do it. On the Pro or Performance skin, click the gear icon next to cue or sync (depending on the deck) and choose pitch range, then a range. It's also available on the Essentials skin. Why not have a look at the page of the manual? https://www.virtualdj.com/manuals/virtualdj/interface/decks/deckbasics/index.html
You can also go into settings, then options, and search for pitchRange and enter it yourself.
geposted Tue 21 May 24 @ 4:29 am
I think OP is talking about setting a range during BPM analysis, not the percentage on the deck.
geposted Tue 21 May 24 @ 9:10 am
