When I create a new empty list and open a history playlist and highlite all songs and drag them into the new empty list, the first song is always last in the order after i close the list and open it again.
When i correct the order it stays correct after close/open.
If i drag songs from the history playlist into a new empty list one by one, the order is correct. What am I doing wrong or is it a bugg?
geposted Thu 23 May 24 @ 7:21 am
Here is a video of the problem
geposted Fri 24 May 24 @ 7:28 am
Can you try with the early access release if it still happens?
geposted Fri 24 May 24 @ 12:16 pm
It is BUILD 8176
geposted Fri 24 May 24 @ 4:04 pm
Try right-click on the column headers and see if 'reset sort order' is available
geposted Sat 25 May 24 @ 8:09 am
"Reset sort order" is not available. Can't see it anywhere.
geposted Sat 25 May 24 @ 1:50 pm
I have also seen this issue since updating to the 2024 release. I'm on a MacBook Air M1 currently on build v2024-m b8124.
geposted Tue 28 May 24 @ 5:48 pm
Now it works in the new release, build 8124. Thanks for fixing it !
geposted Fri 31 May 24 @ 5:46 am
I mean Early access build 8184 :-)
geposted Fri 31 May 24 @ 2:29 pm
