I use EQ10 on all four decks and use the Blocks skin. I would like to have the EQ10 master be on when I open virtual dj. Is there an oninit script that will accomplish this?
geposted Thu 30 May 24 @ 11:04 pm
There's nothing special about oninit, it maps just like any other key.
deck master effect_active eq10 on
geposted Thu 30 May 24 @ 11:36 pm
It does not like the word on. It shows green and does not turn on eq 10.
geposted Fri 31 May 24 @ 11:36 am
Try active instead of on
geposted Fri 31 May 24 @ 12:05 pm
It is supposed to show green...
the issue is the skin/VDJ etc has not fully loaded the instant that the ONINIT script is setting the master effect.
One needs to add a "blink of an eye" (maybe up to a second) before the script is sent.
try:
note:
you may be able to shorten the wait time.. or need to lengthen it a bit.
try:
wait 1000ms & deck master effect_active eq10 on
note:
geposted Fri 31 May 24 @ 12:07 pm
Thanks to everyone's help. It is still not working with all of the suggestions. I will show you what I have in oninit, maybe that is the problem: deck all volume 0.50 & wait 2000ms & deck master effect_eq 10 on
geposted Fri 31 May 24 @ 3:21 pm
fallguy66 wrote :
...deck master effect_eq 10 on...
What's "effect_eq" ?
And be careful with deck all, contain it in ( )
read why here.
( deck all volume 0.50 ) & wait 2000ms & deck master effect_active eq10 on
geposted Fri 31 May 24 @ 3:39 pm
unless you're poorly explaining what you want
( deck all volume 0.50 & effect_active eq10 on )
geposted Fri 31 May 24 @ 3:51 pm
Apparently, I was poorly explaining what I wanted. Your last suggestion worked.
Also, thanks for the link that explained the brackets. While I could work around this issue this fix made it much easier. When I record, I tend to forget to click the EQ10 and then have to start over.
Thanks to everyone for their suggestions. This forum is a wealth of knowledge with so many willing to help.
geposted Fri 31 May 24 @ 4:50 pm
