1. I drag a mp3-file to the first player
2. I select and drag a second track to player 2. At this point they both are aligned at the starting cue.
3. I play track 1
4. Now, by pushing the play button on track 2, to start mixing, track 2's waveform 'jumps' to a position further away, dough normally, VDJ Should just start the file when I click.
I have this since the big update to V.2024 68124. This is very ennoying since I can't mix on the fly anymore. I use VDJ on HP laptop with Win11.
Any suggestions? Maybe it's the new version... or a new setting or so i should change.
Thnx in Advance, Kurt
3. I play track 1
![](/img/406936/59426/Schermafbeelding 2024-05-31 025843.jpg)
geposted Fri 31 May 24 @ 12:57 am
Check your quantize number isn't something large, smart play with a large quantize number could do that.
geposted Fri 31 May 24 @ 3:54 am
Thanks for the suggestion. My quantize option were Yes, Yes & 0.0
I understand what the option does. I set GlobalQuantize to 4, since beatmatching is a question of counting to 4 (at least). For now, it looks ok. Hope it stays that way.
Kurt
Kurt
geposted Tue 04 Jun 24 @ 11:05 pm
