Hola a todos , tengo una ddj rr con Mac Catalina , no me toma la tarjeta de audio , tengo que usar una externa , alguien que ayude que puede ser , gracias.
geposted Sat 01 Jun 24 @ 11:11 pm
check if macOS have blocked the pioneer audio driver, very common it does.
https://www.pioneerdj.com/-/media/pioneerdj/downloads/other/troubleshooting/troubleshooting_highsierra_or_later_e.pdf
unblock the driver, and all should be good ;-)
geposted Sat 01 Jun 24 @ 11:52 pm
try the above first, but it may also be that its not supported in Catalina (but probably is even if not stated)
https://www.pioneerdj.com/en/support/software-information/ddj-rr/#operating-system-information
geposted Sat 01 Jun 24 @ 11:54 pm
