Topic: Using Saved Loops on CDJ3000
DJ1U7PRO InfinityMember since 2015
I'm trying to figure out how to use some of the Hot Keys on the CDJ3000 for "saved loops" but it's not part of the default mapping, and I'm struggling to sort out how to do it.
At one point I got a button to play a saved loop, but the LED did not cooperate at all. At this point I'm wondering if it's even possible, or is that functionality disabled in the firmware somehow.
Can anybody help or point me in the right direction here?
geposted Mon 03 Jun 24 @ 9:56 pm
Since build 8124, there's an option 'hotcueSavesLoop' which by default should be enabled.
When enabled, hotcue buttons now also save cues AND loops (when a loop is active) when you use them.
Therefore the behavior of the hotcue buttons with this option enabled should be similar to what you're looking for.
geposted Tue 04 Jun 24 @ 9:39 am
Amazing! Thank you so much!!
geposted Wed 05 Jun 24 @ 12:34 am
Works perfectly. Makes a huge difference. Thank you for the superb support. VDJ is the best.
geposted Wed 05 Jun 24 @ 12:41 am
