i added this script to the jog to auto switch to the scratch panel
down ? skin_panel 'scratchmixer' on : skin_panel 'audiomixer' on
works well as the audiomixer is the most used...just wanted it to return to the last used panel after it auto switches..which may be not necessarily audiomixer panel
geposted Wed 05 Jun 24 @ 9:59 pm
down ? set $mixpanel `skin_panel 'audiomixer' on ? get_constant 0.0 : skin_panel 'videomixer' on ? get_constant 0.33 : skin_panel 'scratchmixer' on ? get_constant 0.66 : skin_panel 'mastermixer' on ? get_constant 1.0` & skin_panel 'scratchmixer' on : get_var $mixpanel & param_cast & skin_panelgroup 'mixer'
geposted Wed 05 Jun 24 @ 11:21 pm
thanks again loco...works like a charm...this should be added to the scripts page if not there already
geposted Thu 06 Jun 24 @ 1:20 am
