Topic: Crossfader activating decks?
I have the Numark iDJ Live II and it has been working without problems until the recent VDJ update.
I can now longer use it properly as when I use the crossfader Left it activates the right deck(2) and when the crossfader is moved to the Right it activates the left deck (1).
I use the 4 decks and moving the crossfader to the Right it activates both decks 1 & 3 and when moved to the Left it activates both decks 2 & 4
I have uninstalled and reinstalled VDJ but it is still the same.
I have tried another controller I have and a friends controller and it does the same with those?
I am thinking it might be the latest version of VDJ because I haven't had this problem until updating?
Is there a way I can remove this latest version and reinstall the VDJ 2018 version?
geposted Fri 07 Jun 24 @ 10:54 pm
search settings for faderStart
Settings for crossfader are all correct. Problem still ongoing.
I found the problem and indeed you were correct, it was in faderstart but I couldn't see it because it was connected to the 8 deck interface which I looked at and played with for a couple of days, but when I went back to the 4 deck it kept the settings for the 8 deck. All ok now :)
