I cant find anything that solves my problem.
Somehow I screwed up the beat grid on one of my decks and every single track I throw in there has a higher BPM than it's supposed to have and I'm still too new to this to grasp how to do all the advanced stuff. I was going through trying to setup a list of how I wanted to mix songs. They were sounding good, until I screwed up the beat grid on that one side. Now my songs are no longer mixing smoothly. How to reset it?
geposted Fri 07 Jun 24 @ 11:43 pm
rescan the track, or read this https://www.virtualdj.com/manuals/virtualdj/editors/bpmeditor.html
geposted Fri 07 Jun 24 @ 11:45 pm
I've rescanned the track.
If I load a track to deck 2, it loads fine.
If I load a track to deck 1. It is high.
So if the track is 128 BPM? It will be 128 BPM on deck 2, but 129.5 or something on deck 1. It does this for every track.
geposted Fri 07 Jun 24 @ 11:48 pm
so move the pitch slider... press sync, this is all very normal, you move the pitch slider it changes tempo.
geposted Fri 07 Jun 24 @ 11:58 pm
Well I am a world class idiot.
Thanks
geposted Sat 08 Jun 24 @ 12:00 am
FYI.....there is settings > Option: resetPitchOnLoad
you may wish to set it to Yes
geposted Sat 08 Jun 24 @ 3:45 am
