Hello,
When using the cdj export feature, the compatibility in the dialog is ignored and cdjExportCompatibility is used. I checked this by observing flac files being copied or transcoded to m4a:
With an empty USB, start VDJ with cdjExportCompatibility= CDJ2000nexus. Right click a playlist with flac files, export, CDJ, change the compatibility drop down to CDJ400 or CDJ2000, export. The files will not be transcoded to m4a, but we would expect them to with the 400/2000 setting. Similarly, repeat with cdjExportCompatibility=CDJ400 and the dialog drop down with CDJ2000nexus, and the export will follow the cdjExportCompatibility setting and transcode to m4a.
I would expect the export to follow the dialog box setting if changed.
Thank you!
v2024 b8184
Thank you!
v2024 b8184
geposted Sat 08 Jun 24 @ 12:52 pm
Fixed in Early Access release
geposted Mon 10 Jun 24 @ 5:43 am
Thank you for the quick fix!
geposted Tue 11 Jun 24 @ 12:39 pm
