The automix type is set to "Smart (cut)".
I tried
action: automix_skip
action: mix_now
action: mix_next
automix: Mix "Cut"
These all started the next track but did not stop the playing track.
action: stop - succeeded at stopping the playing track, but not at starting the next track.
I created 2 points at the same time: stop + mix_next.
Didn't work, just stopped.
How can I get VDJ to both stop the current track + start the next track?
I tried
action: mix_now
action: mix_next
automix: Mix "Cut"
geposted Wed 12 Jun 24 @ 10:06 am
Also, inside the POI Editor, I want playback to stop when it gets to my exit point, so I can hear if the point is exactly what I want, or needs to be nudged forward or backward, but the playback continues right past my exit point.
Solution?
Solution?
geposted Wed 12 Jun 24 @ 3:20 pm
