DJing tonight. Made the mistake and updated VDJ before.
Now it crash es on my M2 Macbook Pro with the following error:
Translated Report (Full Report Below)
Process: VirtualDJ [1740]
Path: /Applications/VirtualDJ.app/Contents/MacOS/VirtualDJ
Identifier: com.atomixproductions.virtualdj
Version: 8.5.7903 (18.0.8184)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2024-06-13 21:02:33.7150 +0200
OS Version: macOS 14.4.1 (23E224)
Report Version: 12
Anonymous UUID: 10A04692-0A50-8A92-6B52-5F884C40C323
Time Awake Since Boot: 350 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 6 Abort trap: 6
Terminating Process: VirtualDJ [1740]
Application Specific Information:
stack buffer overflow
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x18e3faa60 __pthread_kill + 8
1 libsystem_pthread.dylib 0x18e432c20 pthread_kill + 288
2 libsystem_c.dylib 0x18e33fab4 __abort + 136
3 libsystem_c.dylib 0x18e330694 __stack_chk_fail + 96
4 VirtualDJ 0x1011c2dd8 CVSTPlugin::OnLoad() + 1028
5 VirtualDJ 0x101280da0 CPlugin::create() + 2056
6 VirtualDJ 0x1012b7ca0 CPluginEngine::createPlugin(SPluginFile*, int, EPluginClass, int) + 476
7 VirtualDJ 0x1012b72a0 CPluginEngine::selectPlugin(int, unsigned long, SPluginFile*, EPluginClass) + 764
8 VirtualDJ 0x1012afcf0 CPluginEngine::initDeckPlugins(unsigned long) + 972
9 VirtualDJ 0x100f34b34 CMainWindow::init() + 852
10 VirtualDJ 0x100d613f8 -[CAppDelegate applicationDidFinishLaunching:] + 264
11 CoreFoundation 0x18e506b1c __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 148
12 CoreFoundation 0x18e59adb8 ___CFXRegistrationPost_block_invoke + 88
13 CoreFoundation 0x18e59ad00 _CFXRegistrationPost + 440
14 CoreFoundation 0x18e4d5648 _CFXNotificationPost + 768
15 Foundation 0x18f5f1464 -[NSNotificationCenter postNotificationName:object:userInfo:] + 88
16 AppKit 0x191d7037c -[NSApplication _postDidFinishNotification] + 284
17 AppKit 0x191d7012c -[NSApplication _sendFinishLaunchingNotification] + 172
18 AppKit 0x191d6e674 -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 504
19 AppKit 0x191d6e270 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 492
User ID: 501
Report Version: 12
geposted Thu 13 Jun 24 @ 7:04 pm
previous builds https://www.virtualdj.com/download/build.html
geposted Thu 13 Jun 24 @ 7:05 pm
Didn't work installing previous builds. Only after deleting the program.
Now it works fine again with the old version.
What's the deal with update? What's happening?
Never had anything like this before...
geposted Thu 13 Jun 24 @ 7:32 pm
Looks like the problem is with loading a VST, so the issue may be with a VST you have installed
geposted Thu 13 Jun 24 @ 7:35 pm
Yes, I definitely had some vsts installed... Okay... I see.
Hoping for a fix. Or I'll stick with the old version...
geposted Thu 13 Jun 24 @ 8:30 pm
If you have several VSTs installed, you could start with the VDJ Build that crashes and adding/installing one by one, restart VDJ and see which one it crashes.
Would help us to fix if you could spot the "bad" one(s)
geposted Thu 13 Jun 24 @ 8:56 pm
Or THEY could fix the broken VST functionality on several plugins...
geposted Thu 13 Jun 24 @ 9:20 pm
