Hi guys so I've purchased a new computer and I want to transfer all of my playlist and music and Etc to it. I have a couple of questions.
1. Does the computer name and username have to be the same?
2. Do the songs have to be in the same folders they are on the other computer?
Thanks!
Thanks!
geposted Fri 14 Jun 24 @ 3:27 am
geposted Fri 14 Jun 24 @ 8:42 am
In order to make your life much much easier, the correct answer is:
1) Yes, but username only. Computer name doesn't matter at all.
2) Yes.
There are ways to migrate while the answer to both questions is "no".
But if possible, keep it simple and you can be up and running in much less time.
2) Yes.
geposted Fri 14 Jun 24 @ 12:33 pm
Να σε καλά!
geposted Fri 14 Jun 24 @ 2:02 pm
