I'm using VDJ with two CDJ3000's.
In the last couple of weeks, there have been 3 instances where the track that was playing on one of the decks just disappeared and the deck was no longer loaded. I couldn't get VDJ to recognize the CDJ until I rebooted the CDJ. Even then, it doesn't play properly. VDJ plays that CDJ out of the other deck. So I have to restart VDJ to get it working again.
This is no big deal practicing at home, but I hate the thought of that happening during a performance.
Can anybody help me get to the bottom of what might be happening so I can fix it and ensure this doesn't happen before an audience?
geposted Sat 15 Jun 24 @ 12:15 am
sounds like some kind of connection issue check your cables used to connect the 3000s
geposted Sat 15 Jun 24 @ 12:22 am
Ok, I will switch out the cables. Thanks for the suggestion.
On the Mac, is there a log that might record errors?
geposted Sat 15 Jun 24 @ 12:30 am
