Topic: Stems cut out at start of fade
Hello!
I've noticed this with using stems processed and used in Virtual DJ. I process them before hand and not using the live stems. When I move the stem knob between 12 and 11 o'clock it cuts out the audio of that stem briefly, then moving past 11 o'clock it starts fading it out as normal.
Has anyone else noticed this? Am I doing something wrong?
Thanks!
Lady
geposted Tue 25 Jun 24 @ 3:52 pm
bumping this
Do I just need higher quality tracks? (lossless)
Same issue here
What are your stems settings set at and which equalizer mode do you use?
Sorry this took so long to reply to I went on vaca. So I recorded a little video. It sounds like the highs get kind of muted in that first few degrees of the knob turning. I'm just using the EZ remix stem knobs.
https://www.youtube.com/watch?v=beM3u5W2VZo
