Topic: Save Cues
How do I get Virtual dj to save my Hot Cues? It use to save them. Like when I set a cue in a song and go back to it and it's still there.
geposted Wed 26 Jun 24 @ 3:10 pm
Check if VDJ has write access to the drive where your track is located.
If you create a comment in Tag Editor for the track, is that saved?
Hotcues are saved in the database, on the drive the file is located.
Yes tags are being saved. How do I make sure VDJ has access? I don't know much about tags I dont use them.
