Topic: setting cue point default
orinbeHome userMember since 2019
Im looking for a way or a setting to set default cue points on all tracks. in the poi editor, tracks are set to , "mix fade exit point" or "mix cut exit point", . I would like all cue points to default to the fade exit or start unless i specifically change it myself. is there a setting for that?
Thanks
geposted Sat 29 Jun 24 @ 7:28 pm
