Forum: VirtualDJ Skins
Topic: How do I use MULTILINE ="yes"...?
I'm creating a button which will display text and wish to show it on two lines... e.g. CLEAR PLAYLIST.
Even though multiline is set to YES, the text appears on one line.
The only way I can get it to work is to include spaces between the text to exceed the size of the button. This results in squashed lettering and looks rubbish! I have tried \n but it doesn't work...
geposted Sat 06 Jul 24 @ 1:12 pm
Use textaction, get_text will parse \n correctly.
<button class="button_main" x="+69+69" y="+0" action="sync" textaction="get_text 'SYNC\nTEST'" localize="true" weight=""/>
I believe it should work with format="LINE 1\nLINE2" too, but definitely not with text=""
Perfect, Thanks!
I had to add a textaction placeholder to my button define too, but it works :)
