So I was thinking of adding 4 mini moving heads to my mobile setup, Like my other lights which are in pairs and running in master / slave mode, I would like them to to be synchronized
However I would want them to have just around 200 degrees of movement, basically forward facing, looking at some of the downloadable instructions, I can't see any with a restriction, so I am guessing I would need to a separate dmx control system
So what are people using, would really like. Sound sync on the movements rather than just scenes or pre set patterns
geposted Sun 07 Jul 24 @ 12:40 pm
Moving heads usually do have onboard programs that are designed for different scenarios - at least mine do.
Obviously if you DMX them, they'll do whatever they're programmed to do, but you have the inconvenience of hooking them up to a computer or controller, programming sequences etc.
geposted Sun 07 Jul 24 @ 1:32 pm
I use Chauvet ShowXpress and it works well. Like anything there's a learning curve.
If they are non branded heads you may need a definition written for them.
Apparently the In-Music SoundSwitch is good if you want automation like you're describing.
geposted Sun 07 Jul 24 @ 1:33 pm
Just looking at the cheaper mini heads, to drop on the overhead gantry, they are somewhat limited by the looks of them
Look like it will have to be a dmx solution, will take a look at sound switch
geposted Mon 08 Jul 24 @ 5:55 am
I use 2x Inno Pocket Spot Twins - so 4 moving heads in 2 boxes
They are master/slave mode 2 paired, so that they sometimes move in unison and sometimes move mirrored. And thy are set to sound mode 3, which makes them only move within 180 degrees forward
They are old now, but your can get similar fixtures from other vendors - or buy them used
geposted Mon 08 Jul 24 @ 3:12 pm
Freestyler. A free lighting program that integrates w/ VDJ.
https://www.freestylerdmx.be/
geposted Mon 08 Jul 24 @ 11:44 pm
