"VirtualDJ 2024 is still compatible with m3u playlists, so if you need to use them because they're compatible with whatever you use on your phone, you can keep using them.
The only difference is that in VirtualDJ 2024, new Lists are created in xml format, because 99% of the users don't need the m3u and it's an old and unpractical format."
I read that in a post and was wondering since that is the case, will an XML file playlist export option be included in the export menu? Perhaps that might be a way to export playlists, without the music files, to the cloud (where the songs are housed) to use on another computer? ..ofc while also leaving the automix editor changes intact.
geposted Thu 11 Jul 24 @ 6:49 pm
