Topic: Getting Confused Re List Storage Locations
HI all. I have always run a couple of laptops with music for each on an external hard drive (both with same drive letter) and also the laptops own C drive. The file structures and therefore paths for each laptop are identical. I am getting confused as to where, under the latest version of VDJ with the new My Lists, all the folder data is kept. Previously when making any changes on the master laptop, I simply copied the database.xml from both the F and C drive, plus the Folders file, from the master to the back up laptop and external HD. Now the changes are not being taken. What am I doing wrong? Is there a simpler way? There isn't enough space on the laptops C drive for all the music.
geposted Fri 12 Jul 24 @ 6:47 pm
If you installed in the last year or so then your home folder might have changed
to check your home folder locations match on both machines
and check they both point to the same place.
