Hi,was wondering what platform everyone thinks is best ?!?
I use Tidal because I can’t use Spotify.
Not the greatest……….
geposted Sat 20 Jul 24 @ 8:09 pm
Best for what? Depends what your needs are.
I've used Tidal and I found it pretty good. Found what I wanted most of the time.
geposted Sat 20 Jul 24 @ 9:26 pm
Best for making setlists & playing offline
geposted Sun 21 Jul 24 @ 6:23 am
I meant from a DJ point of view - what kind of music do you need?
From your reply, TIdal fits the bill.
They can all be used with playlists, so that doesn't narrow anything down. Only a few have offline storage though, so (obviously) those are the ones you're limited to.
geposted Sun 21 Jul 24 @ 8:42 am
And the advantage of Tidal, over say Beatport, is that one can also pre-compute the stems for the unlimited, (in number),Tidal offline cached tracks (and most tracks are lossless).
The only improvement, Tidal, could have, is better curation, and a more complete selection of the extended versions of tracks.
(and sometimes hard to find a track on Tidal, even thought its there, and sometimes all 3+ remixes will be named the same... again, some examples of the issue of needing better curation.
geposted Sun 21 Jul 24 @ 9:11 am
