Hi all,
I've been updating track/tag info, things like inserting correct release year for era/decade specific gigs I've had lately.
Upon refreshing tags for some tracks, they are being cleared out as "Track Number Track Title" and Artist etc being left as blank. Weird thing is, VDJ is able to pick up the correct tag info when individual track info is viewed in the Tag Editor.
It's also overwriting old (incorrect) tag info when analysing.
Video below will probably make a lot more sense.
https://drive.google.com/file/d/1mfm52duSKPq2xKv-nUy6dqaIi10PS0ZM/view?usp=sharing
geposted Sun 21 Jul 24 @ 5:09 am
Could you share one of the files after you've cleaned and rewritten the tags in your other program?
Regarding the second problem, if you have setTagsAuto set, and something changes, then VDJ will indeed save the tag with what's in the vdj database.
geposted Sun 21 Jul 24 @ 5:41 am
Hey Adion, I'll send a couple to you via PM.
geposted Fri 26 Jul 24 @ 5:59 am
Thanks, I wasn't able to reproduce the issue though, batch->reload tags kept the tags the same.
I'm wondering if for some reason it was not able to open the file, which is why it read the filename instead, but not sure why that would be, especially since the tag editor shows the tag correctly.
2 things that you could try:
-Try batch->reload tags with setTagsAuto turned off
-Make sure the other application is closed before using batch->reload tags
geposted Sat 27 Jul 24 @ 11:33 am
Some progress! Setting getTitleFromTags to Yes pulls the tags from the file.
So it therefore seems that when getTitleFromTags is set to No, and tags are refreshed, it actually clears out VDJs Artist and Title entries (rather than just "not getting" them).
geposted Sun 28 Jul 24 @ 8:20 am
Ok, I wonder why the songs had titles in the first place then
geposted Sun 28 Jul 24 @ 10:12 am
