Only thing I can think of that vdj is lacking is a better pitch control
seems like when you move the pitch it jumps so far other than that I'm impressed
geposted Tue 23 Jul 24 @ 6:52 pm
          Could you explain this some more? How are you moving the pitch? What about the movement do you find wrong (in more precise terms if possible).
There are quite a few pitch related vdjscript verbs that you can possibly use to adjust the response to your liking as well.
geposted Tue 23 Jul 24 @ 9:54 pm
          But, first of all, what value have you selected as the current pitch range ?
    geposted Wed 24 Jul 24 @ 7:05 am
          Like posted just above it all depends on your current pitch range. If that is set to maybe 6% and you have decent quality pitch fader in your hardware,  it won't seem like it's jumping
If you have a huge pitch range, like maybe 50%, then it will feel jumpy almost regardless of your pitch fader quality
geposted Thu 25 Jul 24 @ 3:46 pm
          ok thanks I'll try 6% and see what happens , I actually had it set to 50% but coming from serato it just seems different
    geposted Tue 06 Aug 24 @ 5:44 am
