I was going through my POIs and there are numerous cue points that I never created. Does VDJ just create these points willy nilly; and for what reason? I started taking them out, but this is going to take weeks to accomplish. Why is VDJ doing this?
geposted Tue 30 Jul 24 @ 6:36 pm
They are created for automix and cause no harm whatsoever. They should also not be visible as actual cue points for example on pads as only the ones you manually set will show.
geposted Tue 30 Jul 24 @ 6:40 pm
Yes, I noticed that only ones that show on the pads (other than the auto mix points) are the hot cues I created. I was just annoyed that they appeared all on their own.
geposted Tue 30 Jul 24 @ 10:01 pm
