Topic: Rane Performer - EQ and Effects
Excited that its being supported. However under no configuration of the EQ/Stems mode do I have control over the EQs. Stems work fine under a variety of conditions but for w/e reason I just can't use the EQs in the standard way they would be used.. the visual indicator in the software suggests it is being activated but there is no effect in the audio. (i checked Serato.. working fine there)
Also.. seems to be the same issue with the effects.. I can select them but when applied.. nothing happens.
I use to have this occasionally on my NS7II and a simple reboot would let my filters filter but this isn't happening this time.
Any ideas? Just be patient? Is anyone else dealing with this?
geposted Sun 04 Aug 24 @ 10:24 pm
