Hello,
Any help would be greatly appreciated...
The limitation of having a 2-channel controller (Rane One). I want to be able to keep traditional EQ on the default knobs and on the playing deck, the Filter knob will be assigned to Vocal (Option is already available) but on none playing deck, I want to be able to change the none playing deck Filter know to stem melody.
For example: Deck 1 is the playing deck:
-Keep regular EQs
-Filter know changed to Vocal (in VDJ drop down menu)
-Deck 2 (None playing) , filter knob assigned to stem melody.
And vice versa when deck 2 is the playing deck.
Is the above possible?
-Keep regular EQs
geposted Fri 09 Aug 24 @ 12:18 pm
action_deck 1 ? deck 1 play ? stem vocal : stem melody : action_deck 2 ? deck 2 play ? stem vocal : stem melody
geposted Fri 09 Aug 24 @ 11:54 pm
