Topic: ddj rev 5 2 laptops 2 different programs
can i have two laptops one running vdj2024 the other running vdj7 pro on the one controller, instead of me having 2 controllers. ( can i run the vdj7 on the ddj rev 5) with pro license? thanks for your help
geposted Sun 11 Aug 24 @ 6:03 pm
2 PRO 2024'S YES
v7 is 10 years passed the use by date, you won't get device support for anything released after 2014.
yes but it is so solid/ ps and i know that been with vdj since the beginning 1996 :)
No you can't use VDJ7 with any new hardware anymore
It was discontinued 10 years ago
It also doesn't really work anymore, for instance it can't do history and it can't use modern hardware properly
- it just too old
Also the sound engine sounds VERY dated - so the master output doesn't live up to 2024 audio quality
