Hardware stems, VDJ and FLX10
I would like to understand how stems work in a controller that calculates stems at hardware level.
I read that Pioneer's FLX10 calculates stems at hardware level because it has an internal processor dedicated to this function.
I imagine that by connecting a FLX10 to a PC with rekordbox during the calculation of stems, PC resources (CPU/GPU) are not used but the internal processor of the FLX10 is used
But if I connect a FLX10 to a PC with VDJ what happens? Are the stems calculated by my PC's video card or does the FLX10 processor calculate them?
In the case in which the internal processor of the FLX10 has to process the stems, what kind of performance does it have? How long does it take to calculate the stems of a 5-minute song?
Thanks.
Thanks.
geposted Thu 15 Aug 24 @ 4:09 am
Not sure where you read that, but it doesn't. It's still the computer calculating stems.
geposted Thu 15 Aug 24 @ 4:50 am
That's simply not true. the FLX-10 has built in hardware FX (maybe the cofusion there), but not when software is connected.
Stems are the same as any other controller, either pre-computed and saved or real time using your computer GPU.
I don't think any controller does that, the Prime 4+ have a beta for stems but it's been running well over a year and seems to be dead in the water. The chances of stems actually being of any quality on an ancient chip is like that literally zero anyway.
geposted Thu 15 Aug 24 @ 5:03 am
thanks you are very kind, you are helping me a lot.
so FLX10 has dedicated buttons for the stems and nothing more, what are the hardware effects for? these hw effects only work if you use the controller as a mixer without software? when you use a software the hw effects are no longer used?
can we say that opus calculates the stems even without a computer/software? or does opus also have the computer calculate the etems?
thanks
thanks
geposted Thu 15 Aug 24 @ 7:26 am
From the VDJ user manual: The BEAT FX section is used to apply VirtualDJ effects to Decks 1 to 4, Master or Sampler and Hardware Effects on the Microphone Inputs.
As stated above, no controllers currently calculate stems on their own.
geposted Thu 15 Aug 24 @ 7:36 am
thanks, I got the wrong information about controllers running hw level stems with their integrated chips, thanks for helping me.
geposted Thu 15 Aug 24 @ 7:52 am
It's possible that the new Pioneer DJ, rumored for a January 2025 release (potentially the XDJ-AZ), may include hardware-level stem separation functionality.
geposted Thu 15 Aug 24 @ 7:57 am
Who knows......
geposted Thu 15 Aug 24 @ 8:26 am
thanks
thanks
the flx 10 just has handy color coded knobs to make stems easier to see. any controller with pads. even my old denon mc7000 can use stems with vdj with the pads. heck, you can even use your mouse. as long as your cpu and mostly gpu are fast enough. the flx 10 doesnt have like a seperate "stems" chip to do the math.
geposted Wed 27 Nov 24 @ 7:19 am
It's possible that the new Pioneer DJ, may include hardware-level stem separation functionality.
Pioneer... being the first to do anything... only being behind software by 4 & 1/2 years . I'd stop listening to whomever is telling you that.
geposted Wed 27 Nov 24 @ 8:40 am
