Topic: Sync folders to lists
Hello fellow DJs!
Do you know if there is a way to sync list data with the files of a folder? I dont want to manually add my new music already sorted in my folders again to their respective vdj lists. Can't the lists automatically update themselves with my new additions? I'm sure there's a way to do it. Or should I suggest this as a new feature / wish?
Cheers,
Daveed
geposted Sun 18 Aug 24 @ 10:39 am
If you want a list that is the same as the folder, why not just browse the folder?
Because the music data (cuepoints, BPM grid) within a folder is only locally stored and does not update in my clouddrive and on my other devices. I have to create a list so everything is backed up and synced but a list does not automatically update when there are new songs added to my main folder...
You can sync a regular folder to the cloud as well
Try using Beyond Compare to sync a whole folder structure from one location to another.
