Hello everybody! I have a DDJ400, and I would like to set 32 beatjump back and forward to the pad7 and pad8. The original settings is: beatjump_pad7 and beatjump_pad8, and with this the jump is only 8 beat. How can I set it to jump with 32 beat?
I tried the following: ‘beatjump +1’ and ‘beatjump -1’. It works with most of the track but sometimes it jumps only 1 beat. How can I fix it? Thank you for your help! Regards: Gábor
geposted Fri 23 Aug 24 @ 3:11 pm
Don't change the mapping actions of the Pads. Best to "Reset" the Page from the Editor
Simply select "Page 7" from the Parameter of the Beatjump Page, so that Pads 7 and 8 jump -/+ 32 beats (8 Bars)
geposted Fri 23 Aug 24 @ 3:41 pm
Thank you for your help and your answer. How can I put into one page the 1 beatjump, 4 beatjump, 16 beatjump and 32 beatjump? Because I use these values most frequently. Now the 16 and 32 are in page 7, but the 1 and 4 are in page 5. Thank you again! Regards: Gábor
geposted Fri 23 Aug 24 @ 9:08 pm
For a limited scope of jumping don't use beatjump*, use
goto
It's a lot clearer as to how it works
Examples
goto +8
goto -32
goto
Examples
goto +8
goto -32
geposted Fri 23 Aug 24 @ 9:50 pm
