I cannot find the clipbank plugin for VDJ 8... Doesn't it exist anymore? The Telly Media and another plugin are announced on this website but cannot be downloaded from the VDJ program. I need to show an image (my logo) as an overlay over whatever is playing, as well as a video (session theme). I used to be able to do that with the clipbank. Is there a 64bit alternative?
geposted Fri 23 Aug 24 @ 8:01 pm
The sampler...
geposted Fri 23 Aug 24 @ 8:23 pm
OMG... I forgot about that thing. Always hated it. I use my own skin and it was simper to make buttons for a dll vst effect. I seem to remember that the sampler didn't accept normal files (jpg, mp3, mp4) but needed vdj files created from within the VDJ program, which is a hassle.
But thanks for the input Groovin! I'll dive into that to see if its any better now...
geposted Sat 24 Aug 24 @ 8:37 am
Sampler does a lot more than it used to. a .png overlay with transparency with Slideshow and/or video adjusted for size will do trick.
( unfortunately 64bit Telly Visuals/Media is kinda stalled. haven't heard from Don (the developer) in over a year and kinda worried he might not be able to work on it anymore or even with us)
geposted Sat 24 Aug 24 @ 2:48 pm
Thanks for the tips!!! I'll get right on it :)
geposted Sat 24 Aug 24 @ 6:47 pm
I must say, the sampler is much much better than I remembered... Lots of options for the samples. More flexible in what it can reproduce also, IIRC.
@wildcountryclub: I got my audio samples instantly working with no problems at all. But I can't locate a tab (in VDJ default skins) for that slideshow you mentioned, to trigger the vids and overlay images (over the master video output)... Or isn't that in the sampler at all, but somewhere else entirely?
geposted Sun 25 Aug 24 @ 2:03 pm
Never mind. I'm stoopid. I needed to change the folder in the browser to get the videos. Also working without a hitch, btw... seemless loops and all!!!
Never thought I'd say this, but... I'm loving the sampler!
geposted Sun 25 Aug 24 @ 2:06 pm
