After the most recent update. I'm experiencing issues with the easyKRM plugin. The update has caused the deck loading and karaoke playback impossible. Rendering the plugin useless. Any suggestions?
Troubleshooting steps so far.
Restart Computer
Uninstall/reinstall plug in
Uninstall/reinstall VirtualDJ
Uninstall Virtual DJ and All of its files.
Restart Computer
geposted Sun 25 Aug 24 @ 11:08 pm
Not seeing a problem here, you're going to have to record a video of the issue.
geposted Sun 25 Aug 24 @ 11:47 pm
I searched but could not find easyKRM anywhere in VDJ... Where can I source it if it's not in VDJ?
I searched several times, even wrote to them, says the never heard of it... Thanks Dave
geposted Tue 19 Nov 24 @ 8:32 pm
geposted Tue 19 Nov 24 @ 8:35 pm
It is in vdj
extensions>effects>other
geposted Tue 19 Nov 24 @ 8:38 pm
