Trying to help a friend out who's been having issues with VDJ2024 and his FLX10.
Looking at his systemreport_session from that night (backed up and versioned by OneDrive).
This is the only thing that stands out as a potential issue:
-- Audio High Cpu Log --
[19:16] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 129.10% (2x)
[20:36] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 128.65% (1x)
[21:31] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 115.89% (1x)
[22:17] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 145.93% (1x)
[22:27] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 173.26% (1x)
[23:00] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 115.86% (2x)
[23:13] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 197.49% (3x)
[23:45] asio://B971FE1B-8569-44E7-9E268D8824398BB5 (DDJ-FLX10 ASIO) : Peak cpu: 197.72% (1x)
Around 23:13 the track skipped, and this is when the audio CPU appears to peak.
Is this the FLX10 audio processor?
Any help would be greatly appreciated. I can add the whole system report if needed.
Cheers,
Roy
The laptop is the same as mine: MSI-Cyborg15 A12V:
Processor: Intel i7-12650H 2.30 GHz
RAM: 16Gb
Graphics: NVIDIA GeForce RTX 4060 (16Gb RAM) (8Gb Dedicated)
Windows 11 Pro: (23H2) 22631.3880
Cheers,
Roy
RAM: 16Gb
geposted Sat 31 Aug 24 @ 10:30 am
What is the latency set to?
geposted Sat 31 Aug 24 @ 10:32 am
Standard 256ms
That was the next thing we were going to try.
Thing is he's had the controller and laptop for over and year, and it's worked flawlessly until recently.
Laptop isnt used for anything other than DJing.
No bloatware etc.
Just VDJ and FLX drivers.
No bloatware etc.
geposted Sat 31 Aug 24 @ 11:25 am
I did a gig last night with the FLX-10 and had popping too. I noticed it earlier in the week when practicing for the set and changed the latency from 256 to 512 but it still happened.
Not happening too frequently but I can definitely hear it.
I had the gig recorded so can clearly hear it when playing back.
Don't recall it happening when I got the controller, it's just been recently.
geposted Sat 31 Aug 24 @ 12:30 pm
Hey Keith,
Thanks for that. Any idea how recently?
My mate is saying since June. Nothing obvious in the changelog for builds 8184/8225's but something to think about/consider.
geposted Sat 31 Aug 24 @ 12:58 pm
Not sure, I've not used that controller much as I still use the MCX8000 for most gigs so they may have been there previously and I just never noticed.
I would think that these pops etc are more to do with Windows and the Pioneer driver rather than VDJ although that machine is on Windows 10 and has has updates blocked for the past 6 months or so.
I will investigate further in the next few days.
geposted Sat 31 Aug 24 @ 2:07 pm
happening to me too, I have the Denon Prime 4 and use stems a lot, latency is set to similar to what everyone has it as, I use the M3 MacBook so don't think its an issue there. Interestingly I had to DJ off the laptop and used channel 4 of my mixer to DJ without the controller (sound coming from the headphone jack to channel 4 via RCA cable) and it worked absolutely fine! Definately some sort of issue when using the denon to control music...I have a backup laptop if it happens again but rather not want to move to another software
geposted Mon 02 Sep 24 @ 11:13 am
I have the Pioneer ddj flx10 and I use virtual dj, I have almost the same problem that audio and video suddenly cut out, since I bought my pc and the driver I still haven't been able to solve the issue, my computer is a Dell G15 5530 Series, 13th generation Intel Core i7, 6GB Nvidia Rtx 4050ti graphics card and 32GB RAM, if there is a solution please share it
geposted Thu 05 Jun 25 @ 4:46 am
