HI,
I would like to connect a old Numark mixer to virtual dj is this possible, the mixer is numark icd mix - dual cd and ipod dj system
geposted Sat 07 Sep 24 @ 8:59 am
It's not a USB Midi controller (or USB Audio Interface), so not sure how you thought it could work with any Windows/Mac computer and software.
geposted Sat 07 Sep 24 @ 9:22 am
i feel like you gave up too soon but thanks, ill let you know my progress
geposted Wed 18 Sep 24 @ 3:48 pm
The only way to use it would involve a separate four channel audio interface, sending the outputs of the VDJ decks to each of the iCDMix line inputs.
You won't be able to control VDJ from the mixer. It doesn't have MIDI or USB.
geposted Wed 18 Sep 24 @ 4:03 pm
