Topic: Reset Mistake is it fixable?
CJHANIPRO InfinityMember since 2011
I have Denon MC7000 as my main I was having issues with the light around one of the Wheels, I hit reset in setting and it fixed the problem. The issue is evidently RESET erase my playlists and history files. Is there a way to restore that. I did not setup a backup.
geposted Mon 16 Sep 24 @ 4:49 pm
They wouldn't be erased by resetting the settings.
After reset it may have moved the home folder from documents>virtualdj to the new windows location. Click on the cog at the bottom right of the settings page and see what's there. You may need to copy your current folder over, make sure to do this with VDJ closed.
geposted Mon 16 Sep 24 @ 5:18 pm
Thanks I found the files in my I cloud and put them back in like you said.
geposted Tue 17 Sep 24 @ 1:12 pm
Glad you're sorted. Woukd have been helpful to mention you are on a Mac though.
geposted Tue 17 Sep 24 @ 1:22 pm
