Apple's newest OS update, Sequoia just came out a few days ago, and they have a few features I want to try out
Does anyone know if? virtual DJ is supported on Mac Sequoia?
I haven't seen anything from Atomix, that I could find.
I tried searching these forms and, Google already and couldn't find it mentioned and I haven't seen anybody mentioned it.
If it's not officially supported, has anybody ran it successfully?
geposted Thu 19 Sep 24 @ 4:32 am
No issues found so far.
If you are using a controller, of course best to check with the manufacturer if it is compatible though.
geposted Thu 19 Sep 24 @ 4:33 am
I updated my mac to Sequoia hoping there wouldn't be any issues and can't log in anymore to my account. I get get stuck when trying to enter and eventually get the "Cannot connect to servers" error. I have checked the hosts and my internet connection but everything seems to be in order.
I would recommend not updating if you use an account for all the virtual dj features
geposted Sat 28 Sep 24 @ 10:27 am
Firstly, I'm an early adopter of new software, I have always used the Early Access versions of updates with zero issues (I know, not recommended for gigging). I am semi-retired and currently have no gigs lined up. So, I decided to upgrade my M1 MacBook Pro to Apple's new Sequoia OS. I have my previous MBP backup laptop if needed. I spent a week trying to upgrade, I tried every 'fix' on the internet with no luck, the (Failed to Personalise the software) error. Finally I took it the Apple Store to get installed, last year I had the same problem with Sonoma which they took half an hour to install. Sequoia took 2 hours to install. On returning home trying to restore from my Time Machine with the Migrant Assistant didn't work. So, I have spent all weekend rebuilding my system back to where it was, still some work to do.
I could not install VirtualDJ which was throwing up a message to contact the software provider. I have a months worth of previous working VDJ versions and I had to transfer one of them into the Applications folder, and it has updated to the latest EA. When trying to run it I am getting a stems engine error. Previously for the last 2 years this laptop has been brilliant with Stems. Has Apple broken something? I have restored VirtualDJ to 'as it was' except the Stems error. I tried reinstalling from the VirtualDJ website and get the Stems engine error and refuses to install. I'm currently running VDJ with the Stems disabled.
Has anyone a clue for a fix? 🤷♂️
geposted Tue 01 Oct 24 @ 9:03 am
Stems will only work on a fresh install. Apples migration tools are broken.
geposted Tue 01 Oct 24 @ 9:12 am
Yeh, I've seen the problems with the Migration Assistant in the forums Keith. Currently I can't download and install from the VDJ website, so its a bit of 'catch 22'. I have a working version that I updated this morning to b8331. It's only the Stems that seem to be broken. I've disabled Stems in the Options for now.
geposted Tue 01 Oct 24 @ 12:27 pm
As a MacOS user that may be considering a machine upgrade in the near future, should this issue + existing workaround + any updates be on a Tech Support Forum page featured at the top (or at least a rehighlight of any existing page that has the info)?
geposted Tue 01 Oct 24 @ 1:27 pm
I have à Macbook Air M3 with sequoia 15.1. It worked fine with the last version of vdj but tonight vdj is opening and immédiatly it s closed... 😢😢😢😢
geposted yesterday @ 1:33 am
