Topic: RTX 4060 not working for stem 2.0
My laptop ha RTX 4060 but Virtual DJ is really slow creationg the stems. I don't know wky but it seems that VDJ uses only one GPU. Anyone could help? Thanks
geposted Fri 20 Sep 24 @ 7:29 pm
Drivers updated?
Versione DirectX: 12.0
Processore GPU: NVIDIA GeForce RTX 4060 Laptop GPU
Versione del driver: 561.09
Tipo di driver: DCH
Livello funzione Direct3D: 12_1
Nuclei CUDA: 3072
Max-Q Technologies Sì
Boost dinamico Sì
WhisperMode Sì
Optimus avanzata No
Massima potenza grafica 95 W
Clock principale: 2010 MHz
Frequenza dei dati di memoria: 16.00 Gbps
Interfaccia memoria: 128 bit
Larghezza di banda memoria: 256.03 GB/s
Memoria grafica totale disponibile: 32634 MB
Memoria video dedicata: 8188 MB GDDR6
Memoria video di sistema: 0 MB
Memoria di sistema condivisa: 24446 MB
Versione BIOS video: 95.07.18.00.EE
IRQ: Not used
Bus: PCI Express x8
What is the speed it shows when you check the tooltip on the cpu meter?
That's indeed slower than it should be. Perhaps try something like gpu-z to check the frequency and see if it's not throttling? Perhaps a cooling problem with the laptop
Thanks
While stems are processing, check the sensors tab, in particular the PerfCap reason.
If functioning properly, the power draw should be around 40W I think, depending on your specific laptop.
Infact. Your are right. I don't know if I can change this settings in my laptop.
9W seems extremely low yes, so perhaps the power plan is set to maximum battery or so?
The reason also says thermal though, not sure if higher up you can see the GPU temperature, but overheating is still a possibility in that case too
Maximum is 90W. 9W only is very strange. I'll continue investigating. Thanks
