I always use my onedrive for all music files, and on my harddrive I enable always keep the files in this folder locally. Now I enabled the clouddrive function ang got dublettes, hmm. So I thought then I can delete the files (in VDJ library) that point to my local folder and only use the ones that start with "clouddrive", but then I noticed that not all clouddrive files have my cue points, ratings and other things I have edited, but most of the clouddrive files have this. Why is it like this? How do I keep all the tedious work I have spent on my files BUT use the clouddrive "versions" of the files? (technically they are the exact same files??)
You see on my 2 pictures there are 2 files in the 60's folders that for some reason refuse to be updated with my ratings.
Why does some files have all the changes I have done, but not some others? (probably the latest files)
geposted Mon 23 Sep 24 @ 3:32 pm
