Dear developers, I am a conference executive, in the process of executing the conference staff intermission, need to be accompanied by light music for a single song loop, VirtualDJ although there is a loop function, but can only loop a small section of the song, we need to loop the whole music or a certain list of music, this is very common in other music players, I hope that your software can also add this feature! I hope you can add this feature to your software, so that it can fulfill the needs of our conference music playback.
geposted Wed 25 Sep 24 @ 7:10 am
nothing needs adding there are several ways.
geposted Wed 25 Sep 24 @ 7:23 am
And also if you are using the software commercially you need a licence.
geposted Wed 25 Sep 24 @ 8:44 am
repeat_song is most likely what you're looking for.
If you don't want to repeat the entire song, then there are other ways to do it, involving setting hotcues and action POIs
Since you are not a DJ, I would still believe that repeat_song action should cover your needs.
geposted Fri 27 Sep 24 @ 9:55 am
Where can I find the instructions for “repeat_song”?
geposted Thu 17 Oct 24 @ 3:37 am
Search YouTube for "VirtualDJ Custom Buttons"
Then put the code on a button
geposted Thu 17 Oct 24 @ 6:41 am
