Topic: Error CloudDrive
As picture below shows alot of my files cant be uploaded correct.
About 30% got "red" instead of "green".
Have restart och check OneDrive. Everythings ok and storage space are ok.
Also deleted everything and restarted but same problem and only 500gb of 800gb is "green" and ok.
Even tried tp use "force" function but nothing happens.
What´s wrong, any proposals?
geposted Thu 26 Sep 24 @ 7:55 pm
Songs from a streaming provider can't be uploaded, they will be played directly from the provider
They are on my harddrive.
All files are only sync to main folders on my harddrive.
When sync "my list" the Tidal songs are as you pointed same "red".
So must be something else
