Hello,
I would like to know if exist a way to tell di vdj skin (default) to start with rack->effect instead nothing and if can be possible to have steams+fx instead cue on pads config even on startup without choose before runnin a performance...
Thanks a lot,
Gianluca
Thanks a lot,
Gianluca
geposted Sun 06 Oct 24 @ 5:19 pm
keyboard
oninit key entry
oninit key entry
... & ( deck all pad_page slicer ) & ( var $fx_rack 1 ? : wait 1000ms & set $fx_rack 1 & load_skin )
geposted Sun 06 Oct 24 @ 9:19 pm
Hi, Locodog and thanks!
you specify "keyboard" on the script.
You mean that this is not valid if I use a console (SC Live for me)?
geposted Tue 08 Oct 24 @ 9:47 am
it IS valid, everybody has a keyboard
geposted Tue 08 Oct 24 @ 11:49 am
OOK!!! thanks a lot,
Gianluca
geposted Tue 08 Oct 24 @ 2:59 pm
