Hello all - I am moving everything into a new laptop from VDJ 7 pro to the current pro version and want to know if there is some way I can keep the amount of times a song has been played. With Prime Cuts and Promo Only I have tons of versions of some of the songs I play and sometimes sort them by that so I can be sure I'll be playing the same version I have been playing for years. Thanks!
geposted Sun 13 Oct 24 @ 11:03 pm
First of all you'll need to convert V7 database files to V8
This is done by running VirtualDJ 8 on the same machine as VirtualDJ 7
Then, you take those files to the new machine.
To do so, you create a backup with VirtualDJ 8 on the old machine, and you restore the backup on the new one.
geposted Mon 14 Oct 24 @ 6:15 am
- Do you know of a video or step by step write up of how to do that?
geposted Tue 15 Oct 24 @ 2:32 am
