Just to be sure about the clean project folder, I did the same procedure again.
Created a new Project folder. With the database added I can start SoundSwitch without any problem over and over again without closing.
Next step: Copiep the Venue file (Where all settings like: Midi, DMX, Static Settings, Positons, Attribute cues.. and so on are set). Re opening the project folder will result in closing down..
Next step: Cleared all midi settings for this venue. Close down the program manually and re opened it; and I finally I was able to just use SoundSwitch. Did the close down / re open procedure three times more and all went well again.
Pretty sure the midi settings where kind of messing up things here, but it's weird, excluding the database kind of solved things for my settings in this specific Venue file.
I now will try to do the same on the laptop I use for gigs, and adress the Streamdeck again. Perhaps there where some previous midi learn adresses specified, but those aren't accesable, and so SoundSwitch will close down. I've worked a lot with midi controllers and never got any problems with it. In my recent setup I've added a Numark DJ2GO which is an additonal controller for my touchscreen (like to have physical buttons). I always have to start Virtual DJ first. When starting SoundSwitch first, Virtual DJ can't acces the Numark DJ2GO. So perhaps it send out midi informations while I was learning my Streamdeck? Don't know..
Will now turn over to my gig laptop to continue the experiment.
geposted Fri 01 Nov 24 @ 10:55 am
Just did the same in my Gig laptop. Clear mid settings in SoundSwitch. Same problem when accessing the database. SoundSwitch just closes down.
And, where as my empty project folder with a copied venue in my clean install laptop without the virtual Midi Cable, Streamdeck app, and midi settings for the venue cleared seemed to run fine, now it is also closing down now. :-(
Back to the startingpoint.. I'm a bit lost.
I sent over my Virtual DJ database to SoundSwitch and could not find any issues with it.
I'm a bit lost.
The only knowledge I have now is that an empty venue (now DMX adresses for fixtures, posistions and stuff) will SoundSwitch acces the Database without closing down.
I also noticed, when the red spot is not lit (indicating SoundSwitch is reading the Database), and selecting performance mode, so just have a little patience, SoundSwitch will continue to work most of the time. But then those random crashes that bugged me the last gigs still are a problem.
I'm a bit lost.
geposted Fri 01 Nov 24 @ 11:48 am
Thank you for providing all of that info. So it does seem like the unexpected behavior is coming from the SoundSwitch side. MIDI controllers being accessible by a single client at a time is probably normal for the controllers you mentioned, and I guess you are using Virtual MIDI cable solution to overcome that.
I also would have looked to the Virtual MIDI setup first for the problems but you said you had issues even without it.
I personally always wait for the library to be loaded before doing anything in SoundSwitch, and I also go to Performance mode to test everything else out without issues (that's probably noy helpful to you though).
I think at this point it sounds like a SoundSwitch tech support problem. Maybe if possible you can provide them with a core dump when the issue occurs?
geposted Fri 01 Nov 24 @ 12:26 pm
Thank you for the information. How do I capture a coredump?
I did not have any response from SoundSwitch, after I provided them the information, SoundSwitch continues working for at least an hour by not accessing the Database. They also asked if the problem persists when I switch the software setting to Serato, as it is not scanning the Virtual DJ database then I think.
Things work great as long as I won't be asking to much of my computer. Things like streaming or setting up an internet connection can close down SoundSwitch. It's just like, if there's too many tasks, the programm acts buggy in Windows. Even when there's lots of CPU overhead.
geposted Fri 01 Nov 24 @ 12:52 pm
I sent over my New created Project folder to SoundSwitch support. The one with the exchanged Venue that is causing the problems on any computer . Hopefully they'll come up with a solution on this.
geposted Fri 01 Nov 24 @ 4:02 pm
You could prob capture a coredump with a user space tool like userdump (I'm not really a Windows user). I think SoundSwitch devs would guide you much better than we can at this point though.
geposted Fri 01 Nov 24 @ 6:49 pm
oh.. thanks for the explanation. I will wait for what SoundSwitch will tell and provide them whatever they need. I really want to start using Soundswitch again if we can sort things out.
geposted Fri 01 Nov 24 @ 8:26 pm
Hi guys. I'm relatively new to SoundSwitch and just starting to set it up (bought the perpetual license for 50% off on Black Friday). I am using Virtual DJ 2024 and Soundswitch 2.9.1. I have been struggling to get SoundSwitch to see my files from Virtual DJ at all. Anyway, I know this thread is a month old, but hopefully we can provide some mutual help. Thanks for the useful info.
geposted Tue 03 Dec 24 @ 4:25 am
@DrivingCapEntertainment I can't help with your problem, but a couple of months down the line, if you get into lamping individual tracks or want to call soundswitch without SS dedicated hardware, I made a thing that does it all inside vdj.
256 nameable commands, upto 1024 events [action cues] per track. os2l or midi.
geposted Tue 03 Dec 24 @ 5:03 am
With respect to library visibility with SoundSwitch, I've always found it missed a lot of my filter folders in my collection (it might be that list has to be generated from the condition of the filter). However I found it read the entire collection and regular playlists (now just lists) ok. Also, maybe you can set browserShowLegacyM3UPlaylists to yes and disabling Hotplug for that list to see if that helps as well.
You might want to just drag all of the filea you want to script into a Virtual Folder and then open SoundSwitch and see if that works (that's the workflow I use).
geposted Tue 03 Dec 24 @ 2:46 pm
An addition to this - if you are updating on MacOS from a fairly old version of VirtualDJ to a recent one, it may be that your older version was using an App folder location that has been deprecated (call this the old location = ~/Documents/VirtualDJ). VirtualDJ now uses ~/Application Support/VirtualDJ for that data (call this the new location). It think it does reference the old data location if it's found, but off the top of my head, I'm not sure what it does for new information (if it still writes to the old, or writes to the new and maintains looking at both - devs would know more here).
To ensure SoundSwitch isn't missing anything, you'll probably want to merge the contents of the old location into the new location, backup, then completely delete the old location, and point SoundSwitch to the new location.
geposted Tue 03 Dec 24 @ 6:54 pm
Hopefully DrivingCapEntertainment is succeeded in importing his files in SoundSwitch? :-)
I still did not got any solution from support, nor were they admitting or able to reproduce my problem of the random close-downs. Support was very slow on this, maybe due to the holidays??
Anyway I think I found out myself what causes the buggy behavior. Fixtures with a high DMX channelcount seem to be giving the trouble. I tried to revert my Project File to an earlier state.. so deleted the last added fixture, and it became stable and was unable to make it crash during the Database scanning. One of the fixtures deleted used 72 channels. I tried to reproduce it in a new created projectfile. Which isn't giving any problems. Adding some fixtures with a high channelcount will make SoundSwitch crash. So it's quite obvious for me when loading the database (20k files in my case) and loading the fixtures, Those with a higher channel count can make SoundSwitch really buggy..
Tested this now on 2 different laptops. (W11). One Intel and one AMD. Both having the same problem as discribed.. it's just like SoundSwitch can't handle all the tasks and closes down when opening Performance or Edit mode and so on will randomly close down during a gig in Performance mode..
geposted Tue 14 Jan 25 @ 8:53 pm
New insights.
It is not so much the fixtures with many channels that causes the crash, but it seems to be multi-cell fixtures. (with many RGB elements). A fixture with 56 channels, which includes 4 moving heads, does not cause any problems, while if I add 4 led bars with 53 channels (Pixelbar Switch 53 channel mode) to a clean started project file, SoundSwitch will easily crash when loading my Database.
My Database had already been investigated and has been completely rebuilt and should be fine according to support.
All this time while I had the 72channel rgb multi-cell fixture in my project file, created by SoundSwitch before they added the fixture creator. At the time I added it (somewhere in 2023) it didn't cause any problem, but at the beginning of 2024 the problems started.
I have shared my experiences with SoundSwitch a few weeks ago (deleting the multi-cell fixture makes SoundSwitch stable again).
Can someone test this for me? Adding 4 fixtures : Pixelbar Switch (53ch profile). And start edit mode, or performance mode while loading the database. My database contains about 20k items. While loading this, and select settings in performance mode SoundSwitch crashes, or sometimes it crashes before I'm even able to move my mousepointer to the settings.
Below is a video with my old Project file.. but the behavior is the same. (I'm on an Intel I9 machine with 32gb). While running this test I had no USB devices added to my computer..
(My Control ONE always starts up without lights on the unit present, does clicky sound and still acts as a DMX interface then. Have to unplug it and plug the USB again to make it functional, which also made SoundSwitch crash sometimes. Does anyone recognize this, lights not showing up? I'm asking because my Control One died when I got it for two months. Can't remember if I had this behavior before it got repaired..)
https://youtu.be/AmkIck-gg_E
geposted Sun 19 Jan 25 @ 10:21 am
Support wasn't able to reproduce the close downs on their computers. I shared my experiences on the SoundSwitch usergroup but my message got deleted. I think people should be aware that sirten fixtures can cause buggy behavior.. I've been struggling with this now for almost one year to discover.
The older SoundSwitch version didn't have problems with the fixtures I loaded.. somehow their later updates can't handle it.
I now tested it on my desktop computer. It's an Intel 14900H with an RTX3050 GPU and 64gb. Same behaviour.
Anyone here who is running Virtual DJ and using SoundSwitch and want to test this? Please leave a comment..
https://youtu.be/kjqd2F5TOW8
geposted Thu 23 Jan 25 @ 5:37 pm
Unfortunately I seem to be experiencing the same issues as DrivingCapEntertainment. I've experienced the random crashes as well, I really want this to work well with VDJ as it's our DJ Program of choice.
One work around I've found on the Beat Grids not being imported (it works roughly 50% of the time) is if you open the song in the VDJ BPM Editor, then Re--analyze (as Multiple BPM), close VDJ so that it writes all the info to the database, open Sound Switch so it reads the database, then the Beat Grids sometimes show up (that has worked about half the time for me).
Agreed that these issues are keeping this from being the go to program for my lighting...
geposted Thu 01 May 25 @ 1:30 pm
It's not reliable at all, and the ilok licence management is a joke.
I persevere with it to use Spectrapix battens with Engine lighting on the Prime Go plus but use Showxpress for everything else.
geposted Thu 01 May 25 @ 1:51 pm
I don't understand what's going on here, I have my ENTIRE library done and it works with VDJ and with Denon standalone with no issue.
Id reach back out to SS and see if that can't get it sorted out. They are pretty good at helping people out.
geposted Fri 02 May 25 @ 4:18 pm
(I really don't like saying this but) It might be a Windows only issue - SoundSwitch works mostly fine for me as well (library reading was always iffy however).
geposted Fri 02 May 25 @ 6:38 pm
Aah, Ok that makes sense. I do know people on windows who seemed to have troubles as well.
geposted Fri 02 May 25 @ 9:29 pm
