Hi
I loop songs and video with a new button
with the command repeat_song.
I have mapped a pad on my controller to turn it on.
How do I map my controller to toggle on/off the same function?
I can not find a command to turn the repeat function off via my controller. I can turn it off with a mouse which doesn't suit my workflow.
Tez
Tez
geposted Wed 23 Oct 24 @ 11:30 am
Press the same button again
geposted Wed 23 Oct 24 @ 11:34 am
Hi
I can with a mouse but not with my controller. There is no response from the Pad, that is mapped, on my controller when pressed again.
Is there a Toggle function repeat_song in there somewhere?
geposted Wed 23 Oct 24 @ 11:39 am
repeat_song is a toggle
Try mapping it on a custom button to see
I assume you use pad pages for your pads
If so, you should also add repeat_song to the "color" mapping of the pad for it to light up at the correct time, or set it to a color
geposted Wed 23 Oct 24 @ 3:32 pm
Hi
Yes it does Toggle with a Custom Button with a Mouse but when I map it to a Pad it only activates repeat_song and does not deactivate it.
Tez
Tez
geposted Wed 23 Oct 24 @ 9:12 pm
I'm not getting into what's happening with your hardware, if it's not toggling then force it
repeat_song ? repeat_song off : repeat_song on
geposted Wed 23 Oct 24 @ 9:31 pm
I will give that a try
geposted Wed 23 Oct 24 @ 9:33 pm
