Hello,
I attached a picture of the manual.
Can anyone explain the marked fields what they are for? There is no explanation about it in the manual. I also couldn't find a video which explains exactly that.
It only appears when you use variable beatgrids.
What happens if I check the box?
What does 1 of 4 mean?
Thanks.
Thanks.
geposted Wed 30 Oct 24 @ 7:46 am
It means that you want the selected bpm anchor to indicate the first beat of a measure.
If not selected, it will continue counting the beats from the previous beat before the bpm anchor
geposted Wed 30 Oct 24 @ 7:48 am
Perfect. Thank you, Adion.
geposted Wed 30 Oct 24 @ 4:08 pm
An extension to this question...is there any value in addition of time signature selection as well?
geposted Wed 30 Oct 24 @ 4:10 pm
The only benefit (for DJ's) would be that the "red"/"blue" markers would appear every 3rd or evry 5th or 8th beat (the value of the denominator of the time signature, with 3, 4, 5 and 8 being the most common, covering the 98% of contemporary music).
geposted Thu 31 Oct 24 @ 8:12 am
I understand. I didn't think non 4/4 time signature play would be that common but you never know (the request might return fom someone else)
geposted Thu 31 Oct 24 @ 5:23 pm
