First of all super Kudos to VDJ for making this software the uber feature-packed monster that is currently is. Your DMX support and integration with SoundSwitch is incredible!
But back onto audio. I use my VDJ Pro primarily for live streaming purposes, ...to Mixcloud and to my own self-hosted Azuracast online radio station platform. I see that VDJ is kind of limited on things you can do for audio enhancements, so I'll bring this up. Many of us DJ's use Thimeo Stereo Tool for audio-processing of our outbound streaming audio signal. Would it be possible to have an options setting that allows for the master audio-out in VDJ to internally port to Stereo Tool (Standalone edition) and then possibly out from Stereo Tool back into VDJ's broadcast encoder going out to wherever were live-streaming to?
geposted Fri 01 Nov 24 @ 6:50 pm
I don't see why the VDJ output would need processing, but still...
Reading the site, it says it's for FM broadcasting. Are you using an FM transmitter?
It also says there's a VST version, which you could simply put across the master output in VDJ...
geposted Fri 01 Nov 24 @ 7:01 pm
the demo of the3 VST2 seems to be working fine on the VDJ master
geposted Fri 01 Nov 24 @ 8:20 pm
just checking on that. Thank you for the responses. I'll try the .vst version locally and see if that works. No GroovinDJ, ...I just use mine for online streaming. I normally have it installed into my radio station platform, because Azuracast allows for direct installation into it, which processes 'everything' coming out of the station platform (including the autoDJ song lineup).
geposted Sun 24 Nov 24 @ 9:16 pm
