I have a problem with Virtual Dj Pro. I've been using it for half a year and at first I was very happy with it. For some time now, problems have started, because of which I had to play a few parties on Serato. Today, the problem occurred again. After logging into Virtual, I didn't have most of the USER List. All the settings in "OPTIONS" also reset to factory settings. I don't know where to look for help. I'm increasingly wondering whether buying Virtual was the right choice. I'll add that I use Virtual on iOS Macbook Air M1/8 Ram. I keep the songs on the desktop, but they are also connected to iCloud. Maybe the problem is in Icloud? I'll go back to the Virtual settings. Is there a file/database and settings that I can save somewhere on an external drive and in case of problems, import it and restore the settings? Or maybe it's possible to make a backup? Best regards
geposted Sun 03 Nov 24 @ 11:44 am
geposted Sun 03 Nov 24 @ 11:47 am
So, did you check the VirtualDJ permissions in the macOS privacy settings as is shown in your screenshots?
geposted Sun 03 Nov 24 @ 11:55 am
Thanks for the answer, of course, the first thing I did was check the settings but in the iOs settings everything is fine
geposted Sun 03 Nov 24 @ 12:01 pm
Hi,
Run it with admin privileged account for a while to remove access rights related causes from the equation , it might be some other access rights than those listed.
geposted Tue 05 Nov 24 @ 10:54 pm
Thanks for the hints. I noticed that the whole situation may be related to Apple iCloud. The library that I use from the desktop is automatically connected to iCloud. I turned off iCloud and I'm testing VirtualDj for a few days. I'll write in a while whether it helped.
geposted Wed 06 Nov 24 @ 9:19 am
